FTO Swaybars
FTO Swaybars
I measured my swaybars front and rear...
Both front and rear were 18mm
Front one is a standard lancer swaybar, and rear one is a standard FTO swaybar.
Searching through the net, I found that the FTO's have standard 16mm front swaybar. Which I thought was odd for a lancer to have a thicker one?
Anyway, I am thinking of upgrading to 20-22mm front and 22-24mm rear. What do people think of this setup?
The car is obviously a lot more noseheavy now (lancer with V6)
The stock FTO fronts are actually 15mm - the readily available upgrade for the FTO is to 18mm - the front of an FTO (designed as sports car) has a much lower centre of gravity than the lancer (the motor is seated much lower) - hence less requirement for a larger stock swaybar. Especially now that you have a V6 in there, I'd highly recommend uprating your swaybars. I went from 15mm to 18mm front & 18mm to 22mm rear & am not looking back. What model is your Lancer? I'd get on the Whiteline website & check out whats available for it (I image there would be heaps)
Just keep in mind if you go too big - you can get 'tripod' syndrome...
When you turn into a steep driveway or street, you may end up lifting the unweighted wheel off the ground... It has happened to me twice now 8O
My car does that tripod thing now anyway! I can feel it rocking a bit when it happens and I've seen it happen a few times when a friend drives it.
I am not sure if whiteline makes front swaybars for my lancer (it's a 2001 CE coupe by the way).
I'll give them a call tomorrow and hopefully it's good news
