Suspension - Strut Mount Pricing
Breza
Post by Breza »
Hi All,
After 6 months with new suspension bushes, droplinks etc etc etc I thought it was about time to bite the bullet and upgrade to some Koni shocks and King Springs.
I am looking at replacing the strut mounts at the same time and got a quote off Mitsubishi for replacement items. Does the following sound correct?
Front strut mount (MR131420) - $174.20 each
Rear strut mount (MB910847) - $69.80 each
Can anyone confirm the above?
I think I may go and buy some Cusuco mounts instead........
Chris
Hey Chris,
Yeah - just been down this road. I've seen prices ranging from 120 - 190 a pop for the front mounts. I went for the Tein Pillows from Camskill UK & they worked out to be $350 AUS landed. Swear by them - great product. Odd thing was thou, the rear Tein tops were more expensive than the fronts 8O So I just put the stockers in. They were $130 for the pair (that was Northshore Mitsi)
Hope that helps :wink:
Ben
Breza
Post by Breza »
Thanks Ben,
I think I'll try to get by without replacing them at this stage.......
Otherwise the Cusco top mounts off www.perfectrun.com.au work out to be about $400 plus freight for all 4.
Not sure if I could deal with the extra harshness in ride comfort though......Tasmanian roads aren't that smooth.
Cheers
Chris
efteoh
Post by efteoh »
sorry guys, but i thought the top mounts came with the suspension.
just to make sure, the top mounts are the top of the suspension with 3 bolts? or is it the bit with with the black rubber bit on it?
Strut Tops
Got mine from Pedders for about $66 each. They are the same as a CC Lancer.
akuma3
Post by akuma3 »
Another noob question, what is and what does strut mounts and bushes do? :(
Top Mounts
Top mount/strut top may or may not come with suspension purchase. If you were to buy full struts, then they do. If you were to buy Bilstein inserts like I did, you dont. They fit inside the existing strut (in other words, you user the original springs, the original strut top).
Best to find out what is included before you buy.
Oh, and the strut top is the bit you see when you have the bonnet open. See here:
http://www.completefto.com.au/FTO_showcon ... 1&pid=1554
akuma3
Post by akuma3 »
Ohhh ... that part, mine for the plastic part is little bit split apart, is that mean i have to replace mine? and what does the stuct top really do?
what about the brush and droplink?
Cap
The plastic cap that covers the nut does not really matter. If its slightly split, will not effect anything. The strut top does have a bearing in it however. two things happen to these over time. Firstly, this thing is made of two bits of metal with rubber in between. Over time, the rubber collapses and you get a nasty metal on metal noise when you go over bumps. All Mitsis of this era are notorious for this problem. Additionally, the bearing will eventually collapse. Short answer: if you have noises in the front end (particularly metal on metal sounds), it is quite possible that your strut tops are on the way out. As to what the strut top does, as far as I know (im not an expert), it cushions the car (to a degree) from the jolts that are sent through the suspension.
As to the bushes, there are several of these, each having its own role in relation to suspension. This is where it gets fuzzy for me. Unfortunately, someone with a better understanding of these parts will be required to explain it in terms that make sense. The little I can explain is below:
Droplinks (these are on front and rear).
http://www.completefto.com.au/FTO_showcon ... 2&pid=1538
Dont seem to have fronts listed
Anti-rollbar bushes (also front and rear) - these are between the anti roll bar and the brackets that hold it on. Can get them (all 4) for about $30 from Mitsubishi.
http://www.completefto.com.au/FTO_showcon ... d=72&pid=7
http://www.completefto.com.au/FTO_showcon ... d=72&pid=8
And for those wondering about pillow mounts - they are camber adjustable and look like this:
http://www.completefto.com.au/FTO_showcon ... 2&pid=2015
After my little 'suspension experience' I am getting bombarded by suspension questions.... PM's, email, MSN. So to all of you that have asked, I will put together a comprehensive post on what to swap out & what not to - with some more explanation.
Complete FTO
And if you dont mind Bennoz, I will put up on Complete FTO too
