anyone keeps a spare wheel in boot?
- GPXXX
No, space savers are not illegal. You can use them during an emergency with recommended travelling restrictions of 80km/h for a maximum distance of 80kms.
In NSW, check out the RTA doco http://members.ozemail.com.au/~crawfy/dl/vsi09.pdf which notes:
Space saver wheels and tyres should only be used in emergency situations and for as short a distance as possible. When your damaged wheel or tyre is repaired, you should put it back on the vehicle immediately.
So, carrying a space saver is better than nothing to save yourself some hassles as a person from the last Sydney cruise found out!
- elmo
spare wheel
The dish in the boot is only big enuf for the space saver, so a 205 or watevr would not fit properly.
nless you made a fance cover or something???
- MattG
- elmo
rims
if the rims stuffed just drive it anyway, cause wont do that much damage to it in a few km.
Space savers are a good idea, they just look poxy.
Then again, they probably do that to embarrass you and stop you going too far with it on?
- rxboy
- elmo
spare wheel
Well if you cant use it in an emergency, you might aswell pull the sub out and remove the wheel and put the sub back. The space left would make a good spot to put amps etc....
Guess you'll be investing in the foam and one of those $6 compressors from supercheap?? (JEEZ six bucks for something like that eh.... a mate got one and has used it a dozen times, not bad for six bucks, cheaper than driving to a servo....)
