-the engine cuts out and wont hold the idle at 800 so I have to manually keep the revs up untill warm.
I then can drive the car but if its not 100% warm then
-it idles high 3000 then drops down to 2000 then to normal idle
-sometimes revs from 2000 to 2500 back to 2000 then to 2500 as if you are tapping the throtle by it self
So my question is - Is this normal? If not what is wrong?
Thanks in advance!
