Got a question....
I know that this has probabl been covered off before, but not sure where so I will ask again. What is involved with doing a tip to manual conversion????
I know that the cluster is different, the console surround is different, the pedal, transmission and shifter assembly is different. What else is involved (apart from the time).
Im guessing that the wiring may possible different as it is for things like the rear aerial.
Im sure there must be a number of people that have looked into this.
Conversion
Plastic piece is the same. Did my conversion and everything fit back perfect....
Off the top of my head you will need:-
Drive shafts (possibly - I did)
Gearbox
Gearhifter, boot & gearknob
gearshift cables
Pedal box
clutch master cylinder and lines
flywheel
clutch & pressure plate
tachometer
Possibly a new Gearbox mount
And of course all necessary fluids....I used redline gbox oil.
Oh also the reverse light plug may have to be changed up a bit to fit back so your reverse lights come on and also the wire that detects the auto in park for the car to start, any half decent mechanic/electrician can sort this out without any issue.. Apart from my custom gearbox mount since I didnt have time to order a new one, my whole conversion took less than two days total.
I think thats about it but stand corrected.
May I suggest getting a short-shifter and LSD if money permits
Gearbox
gearshift cables
Pedal box
flywheel
tachometer
