coil packs
MrFT000
coil packs
Post by MrFT000 »
has anyone replaced the coil packs on the FTO (gpx)
if so, how much and where from?
thanks
My pic was too big.
FTOluv
Post by FTOluv »
yes, i replaced them as i couldnt understand why my car kept on misfiring after i had replaced the leads and spark plugs. Turned out to be one of the coil packs were dead. I called up Mitsubishi and they quoted me $300 for a new one. Called up a lot of wreckers, hardly any of them had it, from the ones that did they quoted $120. I went with a second hand one because they are meant to last a fair while anyway.
So far no problems. $300 is just ridiculous amount to pay for a coil pack :roll:
MrFT000
Post by MrFT000 »
thanks for that info.
how did you identify which coil pack was dead?
my car at cold, will fire up first go,
but after a drive, will take a while to turn over.
My pic was too big.
FTOluv
Post by FTOluv »
Theres obviously 3 coil packs. They are plugged into 3 spark plugs. U should take each plug and check which one is the most worn (usually very black) and check the area that goes over the plugs for any white lines.
MrFT000
Post by MrFT000 »
ummm shouldnt there be 6?
My pic was too big.
Nope - only 3. Each one sparks 2 cyclinders. One from the front & one from the rear bank :wink:
mxysxy
Post by mxysxy »
Bennoz wrote:Nope - only 3. Each one sparks 2 cyclinders. One from the front & one from the rear bank :wink:
but each has 2 spark plugs attached to?
Yep - but each pack sparks 2 cylinders (not at the same time)
If you pull the front rocker cover off you'll see the pack sitting right atop each of the front plugs & a lead running from each pack to the rear cylinders.
I cant remember the order off the top of my head - but its sorta like cylinder 1 & 5, 3 & 4, 2 & 6...
MrFT000
Post by MrFT000 »
so in this image below, those black boxes are the coil packs.
and your saying that its just these 3?
there arent another 3 on the rear bank?
My pic was too big.
afterburner
Post by afterburner »
That is correct - just the three.
It's gone :( - now carless...
Yep - spot on mate. At the rear the leads go straight onto the plugs.
MrFT000
Post by MrFT000 »
thanks everyone.
im getting it checked out tomorrow.
My pic was too big.
MADFTO
Post by MADFTO »
For people who are scratching their heads wondering why there's only half the number of coil packs, here's the long and short of it:
http://en.wikipedia.org/wiki/Wasted_spark
I remember posting something a while back about it all, but that just sums it up nicely.
