Hi Guys,
Can anyone tell me how to go about servicing my FTO. Like what oil to put in and what sort of stuff needs to be changed. I don't wanna take it to the mechanics cause I don't trust the ones arouond here and if I can look after it myself I would much rather do that. So if anyone can give me some tips on how to do this can you please let me know.
Cheers.
Servicing your FTO
- fto_gurl
- HiRAEdd
Oil filter + oil, fuel filter and air filter as far as i know. Someone could elborate though.
All the known mechanical guides written by owners can be found at this amazing resource
http://www.completefto.com.au/FTO_showcontent.asp?hid=104
Check it out!
From what i've seen though there's only a guide on air filer and oil...
Check it out!
- ph3var
Oil and filter every 5k. As for the rest get a service manual for the intervals on the fluids etc. It's not hard to do. The only thing i'd recommend would be putting it up on a hoist every now and then to check cv boots etc.
If you can get a service report, maybe an old one lying around or from a friend or family member, copy it. That will help with all the little things you might normally overlook.
