im a newbie to fto =) but its good to see there is an aussie group here.
I have just got an fto gpx 95 - one issue is the radio is in jap mode and wont pick up any stations. Is there any easy way to fix this
You need an AM/FM modulator ( I thinkt that's what they're called).
I'm assuming you've still got the stock Mitsubishi deck in the car??
I took out my modulator when putting my new deck in the car and I've got it lying around at home....unless Dad chucked it out
Yeah just go to JayCar & get those converter, should be no more then $30. Tell them you got an import radio & you want to pick up the Aus frequence.
Or if you after another cheap solutions then you can get one of those cheap unit from SuperCheap for like $30-$50 bucks
