RPW Extractors, who fitted them?
- spetz
Ok guys since the FTO extractor group buy, who has fitted these into their cars?
Please give a review!!!!
- BuCkEt
No noticable noise change (maybe a little bit louder), but definately a noticable performance change.
The higher revs in first gear keep pulling hard.
Second gear is just damn awesome fun.
Third gear no longer dies out half way through.
Fourth gear can pick up speed pretty quickly when rolling flat.
And I don't have a fifth gear 'cos I drive a tip
Only problem I had with fitting: work shop that fitted them told me they had to extend the down pipe towards the cat a little bit to get a good connection. Took them a little over 3 hours to fit.
Next up....cat back of some sought.
- BuCkEt
- spetz
- ph3var
- FTO338
As with the group buy or in general?? I fitted a FPR when i got mine, & you have to re-map your air/fuel ratio or you be running rich.ph3var wrote:Did anyone notice any "Increased" flat spots as I dont think anyone is running the FPR yet?
- ph3var
- Pato
definite difference in performance and noise. at idle and through the lower reves sounds a lot deeper, however when in the cam change it sounds completely different. a nice mechanical sound, almost a bit harsh, like a M3 when it reves out. dont no if neone else has noticed this, mite just be the mods ive got. the ehxaust shop recons that it mite also have headwork, as the manifolds had been taken off before. he couldnt think of any reason y they would have been taken off. the origional gaskets were replaced aswell and couldnt be reused, so had some graphite custom ones made up.
Next RDO i get i will be getting a FPR fitted and a retune of my unichip. should notice a big difference then!
- ph3var
- smorison
- The Godfather
- ph3var
- BuCkEt
The workshop I was going to get the dyno done at kept saying "we're too busy" and I'd already made the appointment to have them fitted.did anyone do before and after dyno runs?
Haven't had the time to get an after done, but might ask them next time I drop it in for it's service (which is very soon).
