Problem for Installing Dial
- AHJ
is it hard to install the dial onto FTO? if not then i may DIY. moreover is there any shop that can do the installation for me with a good price? since i plan to buy dial, Defi Head Up Display Unit , or maybe some gauge....so i wanna know how much for the installation fee, does anyone install these items be4? thanks a lots!
I'm not so good at translating so i'l just answer what i think you asked
In regards to aftermarket dial faces (ie. to cover the black faces on the speedo, clock, voltage, rpm, fuel etc.) installation is very easy.
In regards to installing something like a Defi HUD (which i have but didn't install) it's also fairly simple. Basically all you need to do is remove the instrument cluster (drop the steering wheel rack first) which is 2 or so screws, then locate the correct wires on the back and your set.
If you follow the instructions of any aftermarket parts like the ones you mentioned you shouldn't have any troubles, its all fairly simple. What I will recommend however is that you skip the application of the window tint patch with the defi unit. It's unneeded and very easy to scratch/bubble.
