EBC greenstuff brake pads
tv2408
Post by tv2408 »
juzt wondering if anyone interested in these pad???
prices are
Front DP2830 $126.40
Rear DP2986 $155.85
i don't know how much these cost at other shops but i can get them for the prices above... :)
benm7
Post by benm7 »
is this for a set?
Does anyone know how easy they are to perform a DIY job replacing them?
Ben
Thats a good price for those.
Brake pads aren't that hard to change although I wouldn't recommend it if you consider yourself a novice. Its kinda important to do them right! :P
afterburner
Post by afterburner »
I've done it, and if I can anyone can :wink:
It's not difficult - the biggest issues are fiddling with the parking brake on the rear set and making sure you take care of the fluid reseviour. Also you are supposed to use a specialised tool to wind in the back brake pistons, but I just used a G-clamp...
But you need to be careful - they're not the sort of things you want issues with later!
It's gone :( - now carless...
benm7
Post by benm7 »
hmmm... sounds tough! So the front ones are pretty straight forward then?
Fronts are ok, two big 17mm bolts can be a bit of a mug to crack & undo. Then pushing the pistons back in can be fiddly - but not impossible :wink:
