Spares
97FTOGPX
Spares
Post by 97FTOGPX »
spare parts in nsw preferably newcastle area, in need of timingbelt, drivers side power window motor can any one give me some good reliable contacts please this would be very much apprieciated, thanks guys
Mitsi Cambelt Partnumber is MD211195 (at least this is what the part number guides quote).
As for the power window motor, try MR101844 (Right Door Window Regulator)
Have you tried your local Mitsi Dealership???. I have found that if I go in and quote the number, they can order for me.
NB Make sure you check the numbers before you buy
SilentBob
Post by SilentBob »
do a search...Gates make one which you should be able to order via any repco, supercheap etc...
btw...where abouts in newy are you? Im one of the only locals who frequent this board....
Red GPX in desperate need of a wash, YOB*** no plates...
I would also recommend Adamstown Car Doctors for mechanical work as mines been there the last few times and they seem to have a clue(and its nice when you call up a place that knows what kind of car you have and also has a decent enough memory to inquire which one mine is(of the few they service))
SilentBob
BuCkEt
Post by BuCkEt »
http://www.ftoaustralia.com/modules.php ... highlight=
Have a more detailed read but the summary of the above thread is:
Fuel Filter: Ryco Z441 ($22 Mitsu)
Oil Filter: Ryco Z411 ($15 Mitsu)
Timing Belt: Gates T987 ($90 repco)
Power Steering / Aircon Belt: 6PK-1080 ($14 Mitsu)
Spark Plugs Iridium: NGK Iridium BKR6EIX-11 ($15 each - Mitsu)
Mobil 1 Oil: $65 (autobarn)
I can confirm the timing belt and oil filter parts from Repco as I've just had my timing belt replaced and the parts numbers are listed on my invoice.
MrFT000
Post by MrFT000 »
those sparkies are for a GR- my mistake there.
I will fix that up soon.
My pic was too big.
benm7
Post by benm7 »
Are these the correct sparkies for a gpx?
NGK--PFR7M x 3
NGK--BKR7EIX x 3 (rear bank)
Cheers,
Ben
97FTOGPX
Post by 97FTOGPX »
Thanks guys i think ill have enough information there to get what i need done, silentbob im from toronto, do u go in newcastle lappin much?
