car squeaks in wet
car squeaks in wet
forum subject basically covers it, car squeaks a lot when its raining, im guessin the belt is maybe loose and slips? i done know
i found that wd40 would fix the problem until it gets rainy again... i tried that for about 6 months and i changed the belt last week and the problems gone...
but you could be right.. maybe it was the belt tension all along... i really have no way of telling...
the belt in particular that i changed was the air con belt... it was in need of changing anyway and since i was doing my timing belt i thought i might as well change it...
simon
simon
"for relaxing times... make it Suntory time..."
- RichardH
The drive belts just tend to dry out after a while. Then, when there's a lot of moisture in the air, they squeak.
I get it when I park in front of the garden retic overnight... or on cold rainy mornings in winter. New belts won't squeak - for a while.
I get my garage to use some lube spray stuff on the belts every so often, to keep them supple. I don't know what they use, but it works well. I do recall they tried a different spray one time, and the bloody belts got so noisy all of a sudden I thought I had a serious problem!!
But reverting to the good spray stuff fixed it again.
- Rich
- Rich
yeh tried tightening the belts and no success the horrible sound stays and i get it in non wet days now too
the belts dont look worn so i dont know, ill replace em and possibly the pulleys, see what happens. Should put a guard or something underneath the pulleys to stop splash getting on them on wet days, just a thought.
i checked the two belts on the drivers side that are exposed, i believe they are the aircon and power steering belts, i also noticed i had a lot of brake dust build up next to one of the pulleys... cleaned it but still squeaks very loud, im embarassed to drive now
sounds horridbur yeh ill try that spray, sounds like the go. Thanx guys.
Also agree... Most of the tensioner pulleys run on grease packed bearings & WD40 will erode that grease away & run the bearing dry. The most common culprit is the alternator tensioner wheel.payaya wrote:i heard wd40 isnt suitable to quieten down pulleys as it acts sort of like a degreaser.
Consdiering its about $80 bucks to replace, just do it when the belt is changed - its suposed to be changed every 80,000kms - and with more 'rigorous'
