payaya wrote:i got one its a bit tight fit! Anyone what would diff in presures mean???
thanks
The radiator cap is designed to hold a certain pressure in the coolant system. Most caps hold 8 - 12 PSI. This pressure raises the point in which the coolant will boil and maintains a good, stable system. If your cap does not hold enough pressure, then the car engine could overheat on hot days since the system never becomes pressurised. By raising the relief pressure all it means is the water in the rad can be cooled by the airflow for longer just before it recirculates.
