hey guys how much does this cost???
i dont want to get ripped off by my mechanic!!!
thanks
and if in sydney where can i get the parts from?
thanks
replacing droplinks + bushes
- fto617
Mate,
Did this myself a while back.
A quick search of the forum..................
http://www.ftoaustralia.com/modules.php ... highlight=
Cheers
Chris
Cheers
Chris
Can get most of the parts from any Mitsubishi dealer although in Sydney, Northshore Mitsubish specialise in Grey imports):
Rear Shock MR17911LB01
Front Strut LH MR131411
Front Strut RH MR131412
Steering Rack MR171469
Anti Roll Bar Bush – Front MR197005 (about $7.50 each - need 2)
Anti Roll Bar Bush – Rear MR197003
Anti Roll Bar – Front MR131542
Anti Roll Bar – Rear MR131431
Drop Link Assembly – Rear MB809354
Drop Link Assembly – Front MR131680 (about $130 for 2 from memory)
Strutt Tops MR131420 ($65 each - pedders)
NOTE: please check part numbers before ordering. I think they are right but cannot be absolutely certain
There are more, but have got these numbers at present
Found Some More numbers:
Alloy Wheel 15" MZ556312
Alloy Wheel 16" MZ556313
Bearing MB303865
Front Knuckle LH MR131213
Front Knuckle RH MR131214
Front Lower Arm LH MR178777
Front Lower Arm RH MR178778
Front Sway Bar MR131542
Front Wheel Bearing BRT1265
Front Top Mount MR131420
MOMO Steering Wheel Boss 12112126110
Power Steering Bottle MR131449
Power Steering Drive Belt 6PK 1065 647
Power Steering Drive Belt MD321692
Power Steering Pump MR171909
Rack & Pinion MR171469
Rack & Pinion beam MR198863
Rear Bottom Arm LH MR197607
Rear Strut bare MR197611
Rear Swaybar MR131430
Rear Trailing Arm LH MR102053
Rear Trailing Arm RH MR102054
Tie Rod MR297969
Wheel Nuts, Locking SP029173
Wheel Nuts, Standard MB579290
Rear bushing 41387 MR102063
Rear bushing 41399C MR197915
Rear bushing 41399B MR102012
Again, check before you buy!
Bearing MB303865
Tie Rod MR297969
