Input speed sensor
APZ-312
Input speed sensor
Post by APZ-312 »
Hey guyz.. i just recently got my input speed sensor changed (code 22) and well.. the problems r happening again.. like when i drive.. it "jumps" from gear to gear and ultimately.. stays in 3rd and the neutral starts flashing.
I have a GR.. 95 model. Can the input speed sensor vary from model to model? mayb that's the problem.. any thoughts? leads?
scarecrow
Post by scarecrow »
Disconnect the battery for 30minutes or so, and see if this solves your issues.
fto617
Post by fto617 »
mate did disconnecting the battery solve your issue???
APZ-312
Post by APZ-312 »
nah disconnecting the battery didnt do nuttin lol..
fto617
Post by fto617 »
do u still have the problem then???
since u changed your sensor
smorison
The Godfather
Post by smorison »
scarecrow wrote:Disconnect the battery for 30minutes or so, and see if this solves your issues.
all that's going to do is clear the error codes, it won't solve the problem
APZ-312
Post by APZ-312 »
i had the part changed all together.. that fixed it up.. that thing which smorison said about the consult unit showed error 22.. which is the input speed sensor.. u should get your checked out and see what error comes up..
but yeah.. most probably your input speed sensor is worn out and needs changing..
