EBC Green Stuff Brake Pads
Private Sales Only
Richc2
Post by Richc2 »
Does anyone in Melbourne know where is the best place to buy EBC Green Stuff Brake Pads for GPX?
Need to replace the rears ASAP.
Please advise.
Thanks
ph3var
Post by ph3var »
Not sure where in Melbourne but it would be a bit of a waste with green stuff on the back I used them on the front and the black stuff on the back works well for me.
Custom purple 1995 GPX manual
Richc2
Post by Richc2 »
Why black on the back instead? is it much price difference?
Thanks
ph3var
Post by ph3var »
Black stuff pads are generally about $100 cheaper fitted then the Green stuff pads. and since the front brakes do most of the work its a bit over kill for the back. Both are very good pads though
akuma3
Post by akuma3 »
EBC green stuff is my last brake pad which is pretty good for braking, the only problem i came across is when i brake the tyre won't hold the ground :lol:
using DBA slot & some weird brake pad now
Richc2
Post by Richc2 »
How much did it cost you for a set front/rear?
Thanks
I just put a set of Green stuff on the front of mine. Pads cost me $185 from Brookvale Brake & Clutch. Labour was 1/2 case of beer for myself.
So $200 :D
kay_8
Post by kay_8 »
i know a friend who can get me green stuff pads for $160.00. I need to change my front pads, dose anyone know the bendix number for the FTO front pads?? :)
Dunno bout the Bendix number, but the EBC Green part number for FTO front pads (GPX) is DP2954.
kay_8
Post by kay_8 »
Thanks for the Bendix number for the pads!!!!
akuma3
Post by akuma3 »
i tried to put a bendix advance in mine when i change my DBA disc, but we order the wrong one so couldn't help you :D
