e-manage
- Quickslvr
e-manage
Hi,
i'm want to buy an e-manage engine control unit (which is blue in colour). Is the standard package good enough to hook onto my fto or do i need addition harness and stuffs. Please give me some advise. Thank you
- spetz
I recommend buying the e-manage + injector + ingnition harness
This gives you control over 16 X 16 map points (16 rev points X 16 throttle positions) of both injector duty cycle and ignition timing.
Quite powerfull piggyback.
I think just installing it without these harnesses is kind of a waste of time
- FTO338
Try to hide the unit its a bitch though. & any cop will defect it with no question ask.
what kind of power increase are we talking about?spetz wrote:I recommend buying the e-manage + injector + ingnition harness
Would it fit in the glovebox? and then maybe a false floor style thing
My pic was too big.
- FTO338
- FTO338
Just out of curious, does anyone know who can install & tune this e-manage in Australia or better still in Melbourne.
- ph3var
- Supplanter
- FTO338
Under Australian law, any piggyback computer modification to the ECU for street car is illegal. (notice 90% of aftermarket ECU company advertise their products on drag cars)
Since its too big for hide away it very easy to spot on the floor of your passenger side. The worst part is, most of the people who i've know got this just leave it on the floor without securing it, which also count as "unsecure load".
But apart from that, i've heard its a great product, you might get away by securing it, & tell the cops its an audio amp.
- spetz
Grant I wouldn't bother changing your unichip either... I'm sure it does the job well enough.
As far as installation is concerned, having read through my manual it looks fairly simple and I think any good tuner/installer should be able to do it. All I would recommend though is get a tuner that has atleast tuned one before and maybe has the software/cable or alternatively borrow it from a friend as it's quite expensive!
- Quickslvr
- spetz
No none of it need chaning.
It's just additional harnesses to control your ignition and injector cycle.
It even has a feature where as if you get say 40% larger injectors, you dial that in and it compensates for them.
If you get the e-manage by itself its a total waste of money IMHO. Might as well get one of those apexi safc things, at least it'll look cool
mm i have a question
is there any difference between the ECU's in the fto?
i got my car dynoed today at 106.4kw, (cai and zorst) and the afr was sitting nicly between 12.2 and 11.7 and the dyno guys looked at it and isntantly asked me what ecu i was using cus it had to be brilliant.... but i know others have really funny afr's ? so whats going on?
not bad for a run on wet tyres huh!
EOI - 96 GPX Brembos, Trust zorst, hks airpod, red seats, 17's
