I just burn all the mp3 on a DVD, beat ipod any day eheheheh
Alpine have got the same thing.
Its good. You mount that little metal box somewhere hidden, and then in my case, ive run the ipod cable up into my center compartment, and made a mount point for my ipod.
the cables are long enough to run it as far as your boot if you want.
the whole point is so that you plug in the ipod, and treat it a bit like a stacker and control it through the headunit
Was thinking about running the adapter cord into the the space under the head unit. Cut a small hole in the back of the facia and the ipod could sit in there and be easily removed when necessary.
There would be the white adapter sitting in the bottom of the bay, but it would still be pretty neat. Should be similar to your setup MrFTO.
And as I'm not lucky enough to have a head unit that reads DVD's...
What model is that? I might check it out.
WildRide wrote:And as I'm not lucky enough to have a head unit that reads DVD's...
WR
Sorry bro, are you asking which DVD unit i've got? If so, any DVD head unit can read DVD mp3, so just find the one you like.
For what it's worth, picked up and installed the unit over the weekend.
Control module is mounted below the head unit (ie behind the facia) and the data cord run through to the glove compartment. So it's all neat and out of sight.
Took me a bit to work out how to get the track info display working, but turned out to be some obscure menus on the head.
Sounds a treat and best of all only cost $130 from JB.
If anyone has a pioneer system and is considering this I'd give it a big two thumbs up.
