Cusco Adjustable Suspension with Upper Pillows Mount
FTO338
Post by FTO338 »
Ok does anyone got a set of Cusco Adjustable Suspension with Upper Pillows Mount, either Comp-S, Zero 1 or 2.
I know they cost more then TEIN, & are super rare, but had anyone ever use them before?
All the things i've heard so far are for other cars, & they suppose to be very good.
smorison
The Godfather
Post by smorison »
do they still make them????
SilentBob
Post by SilentBob »
Ive got the Cusco HA Coilovers with pillowball mounts up front...
bought of someone on here second hand
opinions...well i like them...though ive never adjusted the height of them, and they arent the damper adjustable ones like the Comp Series...
pretty stiff, as stiff as teins...i dont know....
but pretty solid through corners..
FTO338
Post by FTO338 »
smorison wrote:do they still make them????
Yes they still do. And i assume you don't have one for FTO?
SilentBob wrote:Ive got the Cusco HA Coilovers with pillowball mounts up front... bought of someone on here second hand
How much did the front cost you? Do you know which series it is?
SilentBob
Post by SilentBob »
I believe they are the Comp-s series...
the Zero series is where they are damper adjustable as well...
price, well i got all 4 for less than 1k shipped from melbourne...actually...i got it installed for that price to due to some free labour ;)
I do get an annoying rubbing sound because they rub i think on one of the sway bar joints due to the car being lower....
question...being pillow ball top mounts shouldnt i be able to adjust the angle up top to make the suspension sit slightly further away from the mount down near the bottom to stop this rubbing??
SilentBob
FTO338
Post by FTO338 »
SilentBob wrote:question...being pillow ball top mounts shouldnt i be able to adjust the angle up top to make the suspension sit slightly further away from the mount down near the bottom to stop this rubbing??
SilentBob
Yeah I don't see why not.
My understanding is that you said on your first post you got them at the front, & on the last post you said you got all 4, so did you actually installed all 4 or just the front, if just the front, why so?
SilentBob
Post by SilentBob »
sorry, i have all 4...just that i meant with pillowball mounts on the front 2(can you get pillowball mounts for the rear??)
and yeah, i think i need to take it to a suspension/alignment place with a clue and get them fix it...the squeeking annoys me a lot recently :)
SilentBob
FTO338
Post by FTO338 »
I believe the pillow mounts are just for the front. You wouldn't happen to have any pics of your suspension??
SilentBob
Post by SilentBob »
as in on my car, or off just to see what it looks like???
SilentBob
FTO338
Post by FTO338 »
Yeah I want to see what your set looks like :D (Dam I know some of you smartass will make joke out of this line
Does it look like this?
SilentBob
Post by SilentBob »
yep...looks the same ,except the bases of my suspension where blue also....(instead of the slightly tarnished silver colour of those ones)
have pics somewhere, but cant remember where :)
(think they are on the disconnected hard drive)
