Squeaky brakes???
- Rusty12
Squeaky brakes???
What causes spreaky brakes? My brake pads aren't brand new, but they certainly aren't old and do not need changing.
- MattG
Squealing brakes can be cause by a number of things, such as:
1) A rock stuck between the brake pad and the disc (remove brake pads and have a look)
2) Brake dust (give a good clean / brush)
3) The material the brake pads are made out of (change brand of brake pads)
4) Worn pads (remove old pads and fit new ones)
M@
M@
The Data Recovery Experts
- dannyboyau
- dannyboyau
- elmo
brakes
I think the most common cause of squeeky brakes would be glazing over. This is especially common in autos cause you got no gears to slow you down.
Basically both surfaces, the pad and the disk become extremely smoothe like glass and squeel when they rub. This is usually due to slow driving and only using light brake pressure, especially after a hot run.
The easiest way to fix it is to go out and brake hard from sixty a couple of times. This will shed the surface of the pad a bit. If it still doesn't work you may need to pull the pads off and rub em lightly with sandpaper to roughen the surface. Crude but effective.
You may need to change your driving style and brake slightly harder to prevent this from happening. My girlfriends car used to do this all the time but we trained her out of it.
- elmo
ok so here goes
You sound like a pretty cluey kinda chick (unless that is just your tag), have you looked at the How to section on th UK site it tells you how. Give it a go you'll be ok.
Just take the wheel off and undo the two bolts holding the caliper on. Clean em up and put it all back the same and she's all good. Dont disconnect the brake lines and put a brick under the brake pedal so no one presses it. If the brake get pressed while the caliper is off you will have real dramas.
It's pretty easy if you got jack, wheel spanner and I think its 19mm ringy/open ender.
Good luck.
PS would try braking hard a few times first though to save some work.
Good luck.
- YYgirl
- dannyboyau
there is no need to disconnect the brake line you should be able to unbolt the caliper and pull it off replace the pads and put it back on, Just two bolts from memory.
Just checked the funky FTO website he has a great list of how toos there here is a link
http://www.funky-fto.co.uk/index3.html
- dannyboyau
i would do a brake fluid change then
you should change your brake fluid every couple of years as brake fluid absorbs moisture over time and eventually the moisture starts to effect the inside of your brake master cylinder and your calipers causing corosion which then leads to damage to your seals and then brake leakage and then brake failure.
change fluid regular and you dont need to replace costly components
and the brake resevouir supplys fluid for front and back brakes
- elmo
brakes
The reason your mechanic took the line off was that he was putting big new thick pads in the gap where the little skinny old pads were. To do this you need to undo the line and push the caliper back, letting the extra fluid out as you go. You will not need to undo it to clean the pads as they will be same size, if not smaller when they go back in. (as long as no-one touches that brake pedal while off.)
Brake fluid should be changed as part of the 80000k service. If you have never worked with brakes, leave it alone or at least get a mate who has bled a set of brakes before to help.
If you take off the line your brakes will need to be bled to get the air out, to stop the pedal goin spongy and stopping the brakes form woerkin. You will also need to do this with a fluid change.
- YYgirl
thanks!
but bad news, i can't even unscrew the nuts from the wheels, it's too tight!
when you guys have the brake pads first changed in the rear, do they lightly rub on the disc? because i can hear the pads scraping on the disk lightly. I would assume it would probably go away as the pad gets thinner? thanks
- RallyMad
Hi everyone, don't forget that there is also a possibilty that nothing is wrong, some brakes just squeal. For example my mechanic and I have tried to source the problem with my brakes (they've got Pagin pads) to no luck. My mechanic tells me that it's just the vibration between the piston and the brake pad and their is nothing to be done about it. Oh and my brakes only squeal at a specific pressure.
