rev problems
Digital_Import
rev problems
Post by Digital_Import »
Whenever i shift into neutral the car rev's fairly high at 2000rpm, when i put it back in drive or park it goes down back to normal, also when starting the car up from cold it cant keep a steady idle and just stalls and turns off. any clue wats going on here??? :( my fto's been one problem after the next :'(
fto617
Post by fto617 »
ahuh!
popular idle problem thanks to.........STEPPER MOTOR!!!
easy fix
u can try adjusting the idle first
if that dails gotta get a new stepper motor!
Boris
Post by Boris »
you can also try an ECU reset.
just unplug the battery for 30 mins, and conenct again let it idle for 15 mins and see if it helps
