GPX wheel studs size?
nofearzz
Post by nofearzz »
Still on the Mag wheel subject.
What's the stud pattern/size on a GPX?
I know it's 5 studs, but what's the spacing and size... in wheel langauge.
Thanks.
GPXXX
Post by GPXXX »
the PCD is 114.3 x 5 (if that's what you're after) ;)
Std offset is 32 i believe...
As for the bore diameter, i think it's 67...
elmo
wheels
Post by elmo »
OK and is this the same as any other cars in AUS or just Magnas?
rxboy
Post by rxboy »
If you look at rim catalogs of some major brands, only the FTO and Magna are paired.
GPXXX
Post by GPXXX »
You can check the fitment guide for your FTO here:
http://www.takakaira.com/rimsandtyres/r ... irims.html
Different cars have different fitment dimensions, but as stated by rxboy, Magnas and FTO sppears to share the same fitment so it varies...
