yellow warning light??????
paddymac
Post by paddymac »
hey guys,
for the last few days, ive been noticing the far right, top warning indicator
its yellow, a square, with a "opening" in the top, and mayeb a "fluid" in the botom of it, im confused as to what it is, and it only indicates whenever, i turn, or brake with a little bit of force, not a grerat deal though..........
so yeah much appreciate it if some one could tell me what the hell it means.... im guessing its that im low on a perticular fluid.......
It is your G-Force meter... :lol:
Actually, it is your window washer resevoir, you need to refil it with water :wink:
It is located between the fuse box and the battery on th left side of the engine bay.
GPXXX
Post by GPXXX »
be careful though, you cannot just fill it up with any water.... it's gotta be from bottled and chilled Mineral Spring water
if you stick a HKS sticker onto the bottle, you might get an extra 5 psi of squirt from your washer jets...
"...when only the best will do for your car" :D
FTO338
Post by FTO338 »
ahhhh the all time classic, what i do is put dry ice in there, keep it cool all summer long ohh dam summer is over heheehhe :D
BuCkEt
Post by BuCkEt »
You guys are cruel :P
Admittidly I had to pull out my owners book for that one.... 8)
Slither
Post by Slither »
It's your cornering light. If it doesn't come on all the way through the corner then you are going too SLOW!! :twisted:
paddymac
Post by paddymac »
hah thanks guys.....
well i keep it on thru most corners..........
thanks again guys
FTO338
Post by FTO338 »
Pat, I saw you "racing" through York St Sth Melb yesterday, are you in a hurry mate hehehhe
paddymac
Post by paddymac »
hahahaa.... yeah i member that time.......
love to hoon when i know i can......
