dead alternator help !!!
- fto617
hey guys
my alternator died so i'm planning to have it fixed at my mechanic
i can still start my car and stuff but the battery will constantly drop and would probably die in about 15min
so i bought a battery charger and plan to full charge it and try to make a 30min trip from ashfield to northmead(just above parramatta)
Nrma advise me on this and i hope it will work
and does anybody know how to use the battery charger?
do i clip on the battery charger while all the cables from the car is connected onto the car or do i remove all the connections from the car and just plug the charger on the battery?
thanks !
thanks !
- Boris
- fto617
- FTO338
Hmmmmm if you actually read the diagram properly, the one you looking at is for checking battery, & if you scroll down just half a page more, you can see another diagram for charging the battery, which show you connect postive (red) to + & negative (black) to -. Just in case you got confuse, the 120v in the diagram is base on U.S voltage, as its a U.S website, so don't look for a 120v wall socket.
Surely theres instruction in the box when you got your battery charger. And seriously why would you risk further damaging your car? Just tow it.
- fto617
i guss i should just tow it huh....
but i thought i could save some money by charging the damn thing hehe
do anyone think the battery would actually explode? wats the chances of that?
anywayz this is what i dont understand
"Next connect NEGATIVE (BLACK) charger clip to car frame or engine block away from battery."
where is this in the engine bay?
if anyone could supply pic it would be greatly appreciated!!!
thanks
thanks
- SilentBob
- Boris
- onnzo
What a co-incidence. Whilst driving to Mt buffalo for a camping weekend yesterday I noticed my alternator light flicker on as well!
Luckily I was still relatively close to home so I turned around... It wasnt charging when idling but was charging a little when driving,
Anyway. If your alternator is totally stuffed, get a tow. Even if you charge the battery you wont get far without a working alternator and you will stuff up your battery (unless you have a drycell)
When I had a drycell in my lancer (and a stuffed alternator), I got my dad to follow me and every 10 minutes of driving or so he would pull up behind me and give me a charge
You can't do that with a normal lead acid battery though...
Anyway, I have my alternator out now and am going to get it reconditioned tomorrow, ill probably get some new belts too.
- fto617
- onnzo
