What light is this?
umm
What light is this?
Post by umm »
On the rear light cluster, what is the clear part of the light towards the inside. How do you turn it on?
On pre-facelift fog-light pods, there are three bulbs.
Indicator
Middle bulb 3w 12v (fog light??)
Inside bulb 55w H3 (parker??)
How do you turn on the bulb towards the inside of the pod(parker??).
The middle bulb comes on when i press the fog light button or the headlights are on, but i can't get the inside bulb on the back or front pod to work. The bulbs look fine to.
I'm confused, whats what and how do you turn them on? :?
TimmyD
Post by TimmyD »
u talking about the reverse light? when u chuck it into reverse..?
im still confused about which light your talking about though..
effigy
Post by effigy »
Best avatar ever timmyD! :)
thecook
Post by thecook »
bulb towards the inside of the bulb- i think u are talking about the high beams???
and rear light cluster- the clear part of the light is the reverse light, i think thats what u mean?
umm
Post by umm »
Sorry i wasn't clear. Does this help?
FTO338
Post by FTO338 »
Actually your 3V is your parkers & the H3 is your fog lights, all you have to do is press the button on the right had side of your dash near the steering colum.
Cheers
JSP-INC
Post by JSP-INC »
anyone know where i can get the bulbs replaced? both of mine are stuffed or maybe its teh wiring :(
FTO338
Post by FTO338 »
Jun you can get them from any auto shop like Supercheap, Repco, Autobarn, Burson.....etc.
umm
Post by umm »
It all makes sense now. Thanks guys. :)
I found out my fog light switch is melted. and my reverse lights on the back are blown.
FTO338
Post by FTO338 »
Just remember don't use anything higher then 55w for your fog, or you going to melt the switch again.
DZYRME
Post by DZYRME »
I have the same problem with my switch. But I dont know where to source a new switch from. Does anyone know where I can get one from?
FTO338
Post by FTO338 »
I think Kempy (can't remember the actually spelling) in NZ sell them? & there are few member from Oz already brought one from them.
msbchi
light switch
Post by msbchi »
It's a common problem that can only be rectified via a relay. All the fto's that don't have a relay will have melted the switch as the current is carried through a spring loaded ball bearing. I just got a replacement through Lee at SL Motors in Springvale but be prepared they are not cheap $60 was the cheapest I found
JSP-INC
Post by JSP-INC »
FTO338 wrote:Jun you can get them from any auto shop like Supercheap, Repco, Autobarn, Burson.....etc.
thanks dude i reckon my switch hasmelted too or the wiring is stuffed :(
I have fog lights :o 8O
Always wondered what that switch does :roll:
And of course they don't work :P
scarecrow
Post by scarecrow »
Eh, i don't have a fogliht switch or reversing lights!!?!?!
What the hell ay? When i'm reversing i only have the dim glow of my red parkers to guide my way. And when the high beams and everything on the indicator cluster only has a small yellow soft light thing on.
afterburner
Post by afterburner »
Your reversing lights must be busted - there is a sensor on the gearbox which may be faulty.
And not all FTOs have the foglights - I don't have them in mine...
It's gone :( - now carless...
