Help with Speed Limiter / Unichip
Does anyone have any information on the speed limiter for the tiptronic FTO. I am told most Jap cars have the speedlimiter built in the ECU and is very easy to over-ride. I was looking at installing a unichip for better performance and getting rid of the speed limiter. The tech I was speaking to stated that the tiptronic version also has a speed limiter in the gearbox. So a Unichip may not overcome this. Is he right? I understand that the FTO ECU is very good so I will probably not pick up much performance, so is pointless to go ahead if I cannot get rid of the limiter.
Anyone got any info on this?
Many Thanks Jeff.
Many Thanks Jeff.
- MattG
- elmo
delimiting
I spoke to my mechanic about this and he reckons they can put a piggy back thingy in for about $800, this will overide the governor and let you reset the revlimiter to whatever you want. (heard some have been running non mivec 6a12 to 10000rpm)
With this option, at full noise, 5th gear, I worked out a theoretical top speed of 280Kph.
This might be different with auto. Without the rev change, think she will go to 240. Of course friction and drag will be the final deciding factor.
In the UK they do a 180MPH speedo which is 280kmh. They fit a piggy back thing which changes the speedo to MPH and delimits it. Dunno about the revs. This is probably the way I will go, with dual speed RED dials.
Thanks Elmo,
Is he just talking about the rev limiter or a separate speed limiter on the gearbox?
Have you got the contact details for your mechanic, and the device he is talking about? I know the apexi speed meter will piggyback the ecu and override the speed limiter on the ecu, and possibly the rev limiter as well.
Thanks
Jeff
Thanks
Jeff
- elmo
delimiting
The car gets its speed from the gearbox speed sensor, which used to be mechanical on the older cars. It is just an electonic pulse. The thing my mechanic was talking about just changes the pulse to confuse the computer.
The MPH converters can be doctorerd to do the same thing with just a couple of wires extra.
As for the MIVEC/V-tec controllers, well they will do it but they are an expensive option, will probably pay that much for the controller then the same again for the harness, more to set it up properly and still no real advantage, (unless you plan to turbo or go with serious mods)
- elmo
delimting
Think there is a link and a thread on the WA board. http://www.ftowa.com.au
But you need the MPH converter to be able to do it.
- elmo
delimit
Wanna go 120mph and delimit your car for free?
http://www.ftowa.com/forum/viewtopic.php?t=30
Hope that works.
There is a link in that posting to another site that explains it.
Hope that works.
- Theremin
Thanks guys but we are getting a little off topic. The unichip/apex speed meter/ (mp/h/km/h) are all ways to delimit the manual FTO and I thought tiptronic. My question was, Is there a limiter on the tiptronic gearbox as well? Talking to a techie, he told me he couldn`t delimit a tiptronic FTO because of a secondary limiter on the box itself. I hadn`t heard of this before so I wanted to check this out before I forked out for a unichip.
Has anyone else heard this?
Many thanks
Jeff
Many thanks
Jeff
- smorison
- The Godfather
i have an APEXi RSM in my car and there is only one wire that need's to be "fiddled" with to override the speed limiter and it connects directly to the ECU (not the tip ECU).Jeff wrote:Thanks guys but we are getting a little off topic. The unichip/apex speed meter/ (mp/h/km/h) are all ways to delimit the manual FTO and I thought tiptronic. My question was, Is there a limiter on the tiptronic gearbox as well? Talking to a techie, he told me he couldn`t delimit a tiptronic FTO because of a secondary limiter on the box itself. I hadn`t heard of this before so I wanted to check this out before I forked out for a unichip.
Many thanks
Jeff
i haven't taken to the car up beyond 180 but i'm sure it works
- smorison
- The Godfather
interesting point that, up until yesterday I didn't believe it, as the engine puts out the same HP regardless of what gear you are in, but as I discovered yesterday, dyno's don't measure HP instead they calculate it and as such doing a dyno run in a higher or lower gear will yield a different result as the ratios used in the calculation have changed.
MIVEC is My Friend :D
- smorison
- The Godfather
