Now this is a brake upgrade!
mrx
Post by mrx »
http://www.f-inbigbrakes.co.uk/monster_6.htm
Just don't have a lazy 1200 pounds sitting around. Shame that :(
GPXXX
Post by GPXXX »
mmmm 6-piston calipers... *looks at jeff & dannyboy* ;)
you know you could also have 8-piston brakes setup by using 2x 4-piston calipers mounted opposite one other on each rotor lol... (overkill?? mehhh... no such thing! :P)
Would the 310mm fit inside 16" wheels?
And what else do you need to fit these?
What happens if I have 4 stud pattern?
DIGGIDY
Post by DIGGIDY »
310 will fit under a 16" rim, but it depends on the design of the rim as to whether it clears the calipars..
