Warning light?
Warning light?
I found that on FTO's there is this exhaust warning light in the left lower instrument cluster (just under the oil the battery warning light)
Mine doesn't go on for those few seconds with the rest of them on start up. What does this light signify??
Ther
Post by Ther »
its for the exhaust temperature light..when it goes on it means that its way too hot.
HiRAEdd
Post by HiRAEdd »
Perhaps it means "Warning: Your muffler just fell off" ;)
And why does it need to warn you the exhaust got too hot? What can happen from this?
Is the sensor visible on the exhaust? I am not sure if I have one
Ther
Post by Ther »
If the exhaust overheats there can be some problems. Check the FTO manual for a more detailed definition. :)
BuCkEt
Post by BuCkEt »
He doesn't drive an FTO :wink:
aww bucket...
As you saw half of the car is already FTO!
Just in a lighter package :twisted:
LORIDN
Post by LORIDN »
more than likely this sensor wasn't connected by charlie
That's what I'm thinking too Loridin
Especially as the exhaust and even cat is not an FTO item
I'll see if he can connect/find it for me though
LORIDN
Post by LORIDN »
From the looks of it, if the sensor is located somewhere along the exhaust line, maybe charlie didn't get this part when he did your conversion, or if its located in the headers then it may not be connected, it really depends where its meant to be.
Now i'm wondering if people who add an aftermarket exhaust system have this issue, do they adapt this sensor to their new exhaust system or is it completely removed
onnzo
Post by onnzo »
It is positioned just after the cat normally. If you are changing/have changed your exhaust you can just weld a bung in after the cat and screw it in.
If you want to run without it, remove it and put a 100k ohm resistor on the plug that connects to the sensor. It is normally located under the drivers seat.
I dont know if it was carried over in your conversion - it might have been snipped off.
