Outside Temp on Climate control
- spetz
Has anyone found this to be quite inacurate?
Mine always seems to be showing a warmer temp than what it really is
My car doesn't have it (go the GPvR manual air con), but my old VR-4 used to. And yeah, it was a bit of a liar at times. I found that having the car sitting in the sun on a hot day would throw it way out, or sitting with the engine idling for a period of time. Although I did discover one rather chilly day that when it registers an exterior temp of 0°C, it started beeping to warn me...
It's gone :( - now carless...
- HiRAEdd
Re: Outside Temp on Climate control
Dont say that now!!!!!!!spetz wrote:Has anyone found this to be quite inacurate?
I bought 2 new temperature sensors and display units to measure the efficiency of my new CAI box. One in the CAI box, another in the engine bay. Also was using the stock outside temperature reader to compare it to outside environment.
Now you guys saying it is inacurate. I have to get the third one of those temp sensors now.
[img]http://www.smyrnaie.com/SeatCovers/FTO/ftobanner.jpg[/img]
- Grue
Mine is usually wrong, and sometimes by quite a bit. I always remember the cruise to Lithgow - we lit a public bbq to try and keep our hands warm, but the bbq plate was only getting warm at best. It was never going to cook anything it was soooo cold.
However, got back in the car and it tells me that it is 18 degrees. Yeah right!
Usually 3-4 degrees out though.
I have checked mine against a calibrated Thermo Couple from work. on my car it was reading within 1 degree from about 16C to 32C. Because it is just behind the front bumper, when the car is stationary it should give a high reading from radiated heat from the engine or heat build up from the sun. but after a couple of hundred meters driving, it should give a reasonable reading.
Tarkus (Robert)
Tarkus (Robert)
