The Eaton Model 62 supercharger was engineered for 2.0L to 4.0L passenger cars and light truck engines. It was designed as a compact, flexible supercharger for increased power without adversely affecting fuel economy. The M62 has proven to be suitable for other engine sizes depending on overall system requirements.
~Most installations see a realistic 40% plus increase in power output.
~Eaton Superchargers will work effectively in any orientation (Flat, upside down, on edge).
~Different length drives are available, giving the custom installer flexibility in the placement of the supercharger.
~The M62 is available for counter rotating engines (2 Piece Drive).
~A Bypass Valve is included with every supercharger, two different Bypass Valves are available, one that mounts directly on the intake port, and one for remote mount.
And with the 'Eaton M-62' (IV Generation) being priced @ $2,900.00 this sounds like it might be a viable & worthwhile modification to look into...I am making my own enquiries but I was wondering if anyone out there who has a bit more knowledge in the engine field would care to share their thoughts on this topic?
