Starter motor removal
KEA7IN
Post by KEA7IN »
Hello all
I'm having trouble removing my starter motor
can remove the bottom bolt 14mm but cannot access the top bolt very easy and cannot tell the the correct size bolt think it may be smaller tham 14mn
Has anybody removed or replaced there's any can advise me
any advice much appreaciated
Thanks
DIGGIDY
Post by DIGGIDY »
It will be either a 12mm or 14mm bolt... its the one thats bolts into the bellhousing at the top yes??
you will have to undo the oil filter drip plate as well as the starter fools that... then its just a case of jiggling it around a bit to drop it out..
