these are a few questions i was wondering if you guys can help me with-
can FTO GPX-R brakes front and back work on a 98 GLXi lancer sedan?
I currently own one and would like to install a FTO 6A12mivec with gearbox and was curious if these parts will fit exact or will work need to be done.
Also I have seen on you web site someone mention that the FTO front brakes are the same as that of a EVO 5?
if you guys could shed some light that would be great, as for your site its pretty awesome. You guys are doing really kool things with these FTO's. Makes me wish i had one.
sry 2 bother buh can FTO parts fit on a lancer?
- LANCERCHILD
- Supplanter
- FTO338
Re: sry 2 bother buh can FTO parts fit on a lancer?
I don't think is EVO 5, but they are same as EVO 3, which also same as RVR Hypersport Gear from memory.LANCERCHILD wrote:Also I have seen on you web site someone mention that the FTO front brakes are the same as that of a EVO 5?
- spetz
Are the Galant brakes the same as FTO brakes? The older galant that run 4G63 in it's VR4 form?
Anyway most things from an FTO fit a lancer.
This includes brakes and engine/gearbox.
For the rear brakes you need to put the FTO rear control arms to convert from drum to disc.
Even the FTO instrument cluster fits
