car keeps turning off
bazz
Post by bazz »
hey guys. i got a prob with my fto. everytime i come to start it in the morning it turns off if i take my leg of d accelerator. i have to keep revinvg it till its warm, then i can take my leg of d accelerator without it turning off.
anyone got any idea what it could be???
cheers bazz
mrx
Post by mrx »
Not sure what it could be, but try resetting the ecu (disconnect battery for about 1/2 hour), then start and let idle for 10-15 minutes until it is up to temp.
My car does that if all the sensors have not reset properly. Worth a shot.
gfreemantle
99% sure your stepper Motor
Post by gfreemantle »
99% sure your stepper Motor has failed. dead easy to fix.
option 1 tke the old one out a recondition it or 2 get a new one.
http://www.funkyproduct.co.uk/item_deta ... prodID=837
for a new one and the old one is located under the air intake hose. just losen the srew at the bottom end of th intake hose and pull away from the air box. Losen the srew at the top where it connects to the intake manifold and throttle body. the hose will then twist up. Just be carfull not to damage the small tube that comes off of it half way down.
you will now see the stepper. held in by 2/3 screws just undo amd the stepper will pull free. disconnet the plug from the ECU and refit the new stepper.
Robert ya Fathers Brother.
bazz
Post by bazz »
yeh mate i think your right bout the stepper motor. im gona get it replaced n hopefuly thatl do the trick. thanx a lot buddy
cheers bazz
ed
Post by ed »
Anyone knows where to recondition it, and how much? btw Im in sydney?
YYgirl
Post by YYgirl »
when you take off the stepper motor to give it a clean, do you need to clean the insides of the hole that's attached to the car body??
like i can clean the stepper motor itself when disconnected, but how about this small hole attached to the engine?
cant believe this question still comes up! 99.9% stepper motor!
YYgirl
Post by YYgirl »
do i need to clean the small hole that the pointy bit of the stepper motor fits into... (it is attached to the engine not the stepper motor itself)
smorison
The Godfather
Post by smorison »
i've never bothered to clean that...
if it has a large amount of carbon built up on it (the black stufF)... take off the whole throttle body and give it all a good clean
YYgirl
Post by YYgirl »
yeah i've sort of twisted up a long thin cloth and put it inside that little hole, and i found that there was a lot of black stuff when i pulled the cloth back out..... i mean A LOT.... kinda scary.... but i wasn't sure if it was meant to be there or if it's rubbish, so i didn't keep getting it out.....
ScottyTav
Post by ScottyTav »
I think this is happening to me! I just bought my car yesterday and now it won't start! It kicks over and then just dies. Does someone have a photo of where this part is exactly so I can clean it? I don't know a thing about this car yet so please explain it for me very slowly please. Thanks!
Is this 99.9% most likely my prob? Yesterday it was running fine when I bought it and I drove it for a few hours and started it a few different times. Then today this! Always my luck.
Does a clean fix it or does it need replacing?
Is there anyone around Balmain in Sydney that knows about this?
kozi
car turning off
Post by kozi »
Hi, I had exactly the same problem. I gave my mechanic copies of the stuff I got from the forum, and he cleaned the steppa motor no problem, cost me $100. Before that it had been in 3 times, and everytime he thought he'd fixed it , it happened again! It took about a week to settle in and idle at the right revs, first couple of days I had to warm her up for only a minute or two.
Good luck!
