I have a Climet control unit installed and the Aircon/Vent fan on my FTO GPX will not work on the internitant speeds........... Yep Stange as it sounds it I increase the fan speed, shows it getting faster on the LCD display but does nothing. That is until you get to the top speed and then it clicks in and comes on full tilt. decrease the speed by one notch again and the fan dies again.
Happened about 6 months ago but fixed it's self. Now failed again. I have reset the ECU and internal Microprocessors by disconnecting the battery for 1/2 hour and no change. Al cheched the sensor hose is correctly attached which it is.
Any ideas anyone before I start digging.
Weird GPX Vent/Aircon Problem any ideas
Right I fixed it
Right failing suggestions on here I set to work and prodly I now boast the fact that I located and fixed it my fault aircon problem myself. So chuffed to bits I thought I would share my newly gained wisdom so if anyone else suffers the same thing my experience may save them some time.
In the passenger footwell the back of the Air Cooler can be seen and going into this is a 4 pin connector with one a blank.
Take this out and the fan only comes on on the highest setting. Put it back in and it has the full range of speeds. The plug my connector goes into is slightly damaged so was not making contact all the time. (Prob caused buy a tall persons feet kicking it)
Did supprise me how it is in a kickable place I have to say so cant imagine it will be an uncommon fault and hope my experience may save someone else a repair bill.
- HEX093
Fan speed
As a New member I've just got the answer to a problem before I posted question When the little black car gets home I'll look at that connector twice now the fan has run at full speed and wouldn't turn of until ignition was turned of
