If I rest my foot on the clutch pedal it seems to have a very present vibration. The vibrations are only felt through the clutch and none of the car vibrates
It seems to be rpm relative
It has had the gearbox reconditioned and a Daiken Exedy HD Clutch.
What can cause these vibrations? Could it be unbalanced clutch/flywheels?
I noticed most cars do have a slight vibration.
Problem is this isn't a "slight" vibration?
I am thinking the clutch/flywheel might not be completely balanced?
When driving a manual FTO I actually noticed that the clutch let through minimal vibrations.
Well if I press on my clutch pedal I feel a pretty big vibration on mine.
So if it's supposed to only have slight then mine has problems.
And I have already replaced my clutch and flywheel machines some time ago.
