Knocking Noise (metal to metal sorta)
HRD2BQT
Post by HRD2BQT »
Hi guys,
I have recently replaced my old engine mounts to a much newer n stronger ones and it helps eliminate the knocking noise. After a month or so, another weird knocking noise came along. Definitely not from the mount again.
Could it be the rubber bushing all around?.....It only happens when taking off and occassional braking. Also when going over a speed bumps or potholes. I can also hear it when turning to left. Suspension problem??
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
[url=http://z8.invisionfree.com/tgz_gc/index.php?showforum=23]J-Spec MotorWorks[/url] [b]<---click here [color=Red]NOW TAKING ORDERS!!![/color][/b]
Jase
Post by Jase »
I have the same prob. It's not your struts or bushes cause i've had them done. Can anybody help with this one?
Boris
Post by Boris »
It's not the latch on the bonnet is it? Sometimes it could be that. :?
Jase
Post by Jase »
It sounds like a suspension noise. Only hear mine on sharp bumps etc. I'll take mine in on mon and see what they come up with.
EURO
Post by EURO »
i find that when driving down a bumpy road or over speed bumps i get a knocking noise around the rear of the car... sounds like its coming from suspension area as well. its not always there, but down uneven road it often is. it annoys me a lot, but get around by turning the stereo up lol
dannyboyau
Post by dannyboyau »
sounds like it might be the rear drop links
HRD2BQT
Post by HRD2BQT »
I'll get my front n rear drop links check on the weekend and see if thats the one causing those annoying knocking noise.
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
Jase
Post by Jase »
Sway bar bushes. Had mine looked at today. Apparently the cross member has to come down. My guy reckons it's gonna be one of those jobs. Gets done next week.
HiRAEdd
Post by HiRAEdd »
I had the whole box and dice. Loud knocking, front and rear, absolutely terrible over uneven road.
Totally new struts and springs fixed the problem :)
I was going to fit new drop links but twice they told me the ones I had were fine. They also said that the harder the ride (combo between size of wheels and stiffness of suspension), some knocking is inevitable. The drop links have a hard polyurethane (sp?) joint inside them. In your hands they feel solid and smooth, but put a tonne of car pushing on them and they do give a little bit making for a slight knocking noise in some situations on a hard ride.
