flashing *NEUTRAL*
krayzee_sexc_g
flashing *NEUTRAL*
Post by krayzee_sexc_g »
hey guyz, does anyone know what it means when the 'N'flashes on the front panel :?:
im going to get it checked as soon az i get time but juz thought i'd ask around 1st.
Boney
Post by Boney »
im fairly sure Flashing [N] designates a fault .. take your car to somewhere with a digagnostic comp.. to pull out the info to advise what the problem is...
had the same thing happen to my car.. but i had the 3rd gear light jammed on as wel as the [N]... ended up being a major transmission fault...
hope you have better luck! ;-)
hnm738
Post by hnm738 »
how much did the transmission cost to fix?
