Hey all, just wondering how much oil to put in my gearbox.. 6a12 manual engine..
CHeers
Gearbox oil..
- IN_UR_AZ
- dannyboyau
there is a drain plug( 24mm socket ) on the passenger side of the gearbox/diff almost directly below the passenger side drive shaft.
the fill plug is at the front of the gearbox about 3 inches up from the bottom, i think it was 17 or 19 mm socket. I suggest you go to the local vet and get a 60 or 100 ml or bigger syringe for about 3 to 4 dollars, commonly used on horses. Is excellant for filling the gearbox.
you fill the gearbox while car is level, ( normally done on a hoist ) till it starts to come back out the fill hole.
