Making a 6A12 go hard!
- spetz
How much power would I reasonably get from a modded V6 MIVEC, keeping it N/A?
What is the best route for power?
What parts?
I want my car to be quick, like turbo quick (if possible)
The engine is in a coupe lancer
What parts?
- FTO338
Theres few guys including myself are trying to get much out of N/A as possible, so far i know one member had achieved close to 120kwatw in N/A form, is impressive consider that stock is 90-100kwatw.
I'm aiming 130kwatw by the end of the yr or early next yr so finger cross. Mind you, so far all the turbo FTO had reach 150kwatw easily. So unless you going to spend big bucks, its going to be very very hard to achieve what a "hairdryer"can do.
- spetz
I was thinking because my car is much lighter than an FTO, I already have an advantage.
To be honest, 120kw/atw is what I would expect from a stock FTO, considering they have 150 flywheel kw. I never quite understood the reason of the wheel kw being so low.
A friend has a mildly modded 1.8 SOHC (5mm oversize TB, CAI, extractors/exhaust, FPR and e-manage) and got 83kw atw with a rough tune. Are these 6A12 MIVEC's pretty crappy engines???
- fto617
I would say that the dyno your friends lance was one was rigged a little, last dyno comp i went to ftos all ran 103+kw and 1.8l sohc (modified) lancers ran 50-55kw.
As for your car beeing lighter, i thought lancers weigh more then an fto. at least with the 6a12 i guarentee they would wight more then an fto, which is why i wonder why people put 6a12s in lancers
- spetz
Lancer's are lighter than FTO's...
My Lancer's weight (before transplant) was 990 kg, an FTO is 1170kg.
I assume my car now will weight about 1050 kg or less.
I wasn't saying the 6A12 is crap, I was asking if it is overrated? It's hard to believe it loses approx 55 kw through the drivetrain? A stock lancer 1.8 usually does around 60 kw atw, 86 kw flywheel
- SilentBob
Can you show me a 10 year old, 2 litre, normally aspirated engine that offers better performance?spetz wrote:I wasn't saying the 6A12 is crap, I was asking if it is overrated?
Personally I think the FTO and its engine is understated and often overlooked.
What's hard to believe? Both the Lancer figures you quote as well as the FTO figures equate to basically the same power loss (roughly 30%). Between 30-50% loss through the drivetrain is fairly standard depending upon the age and condition of the vehicle and whether it is manual or auto.spetz wrote:It's hard to believe it loses approx 55 kw through the drivetrain? A stock lancer 1.8 usually does around 60 kw atw, 86 kw flywheel
MIVEC is My Friend :D
- kay_8
When you assume your Lancer will be 1050kg, Is that only with a engine transplant??? If so have you considered that the gearbox, suspension and brakes, all these upgrades will increase weight. These upgrades will help your car keep up with your new engine. There is no point on having a fast car if you can't, put the power to the ground, hold speed through corners or stop the car when braking. I have a Lancer as well as an FTO. I have tought of doing a transplant on the Lancer before. When i factor all cost involved it was cheaper to buy an FTO. At the moment they are at such good value.
Amenkay_8 wrote:When you assume your Lancer will be 1050kg, Is that only with a engine transplant??? If so have you considered that the gearbox, suspension and brakes, all these upgrades will increase weight. These upgrades will help your car keep up with your new engine. There is no point on having a fast car if you can't, put the power to the ground, hold speed through corners or stop the car when braking. I have a Lancer as well as an FTO. I have tought of doing a transplant on the Lancer before. When i factor all cost involved it was cheaper to buy an FTO. At the moment they are at such good value.
The defence rests, your honour.
- Boris
Hmm. Don't you think we're being a bit bias here?
As much as I like the FTO, I don't think there is such a thing as the best engine, sure there aren't many 2L engines like ours in that timeframe but that doesn't make ours the best.
What I really wanted to say is that, Spetz, if you're that concerned with your car being slow, post up some figures here, or come on the Canberra soon to be night cruise and drag me, or any other FTO and see how you compare.
- FTO338
I've got to say this, standard FTO (non force induction)are over rated by FTO's owner, & big time under rated by others.
