cylinder compression
hey all
does anyone know what the normal cylinder compression should be? i did a compression test on the weekend but i dont have a benchmark to compare to...
cheers
simon
cheers
simon
"for relaxing times... make it Suntory time..."
ah... im not sure what blow by is but if you compression is low, then either your head gasket is gone, your valve arent closing properly (ie bent valve or valve seals gone), your spark plugs arent sealing properly, or your piston rings are fried....
simon
simon
blow by is something to do with gases leaking betweenthe piston and cylinder wall. I think it is a sign of major engine wear, and a proper seal not being made between pistons etc....
if head gasket is gone, would your car still start? and if your piston rings etc are fried... wouldnt u find the car lacking a lot of power? surging.. etc?
thanks chiangstar..
thanks chiangstar..
if theres a small leak in your head gasket, you car will still start.... youll notice things like your coolant disappearing, bubbles in the radiator water, engine temp increasing, murky engine oil.... but yes it will still start....and the worse it gets, the worse itll perform and eventually just cut out....
i was recently told by a mechanic friend that there can be around 10% variance between each cylinders compression... when you start getting closer to 20% you have to start to worry.... and you will notice it too
Simon
Simon
