tire size help
- andie066
tire size help
hey guys i need help i just bought 16 x 7.5 inch rims and i need tires.. what tires would fit on these rims?
u should get the widest u can fit without rubbing the tyres to the guard..
so I would suggest getting 215 / 45 / 16 or 225 / 45 /16
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
[url=http://z8.invisionfree.com/tgz_gc/index.php?showforum=23]J-Spec MotorWorks[/url] [b]<---click here [color=Red]NOW TAKING ORDERS!!![/color][/b]
J-Spec MotorWorks
ABN 26 086 418 755
Check out this page (half way down):
http://www.mivec.co.uk/q_and_a/q_and_a.htm
215x45R16 looks like the winner though.
From FTO to EVO......
205 / 50 / 16 will fit but I dont think a good set up for 16x7.5 wheels. Wider wheels obviously need wider tyres.
215 / 45 / 16 is far most the best option so far without compromise
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
J-Spec MotorWorks
ABN 26 086 418 755
- andie066
as i said...nothing s wrong with it...u can still use 205 / 50 but it'll look funny coz your rims will stick out in which im sure wudnt want coz if u lets say hit a gutter/curve then your precious rims is fcuked more that u can ever imagine. Personally I would prefer tyres which is a little wider than the rims this will also help improve traction a little bit
Eoh Rimando
J-Spec MotorWorks
ABN 26 086 418 755
J-Spec MotorWorks
ABN 26 086 418 755
- csvperformance
- FTO338
If you get the right offset (not your PCD 114x5) for the size of wheel you want, then your tyres shouldn't be rubbing.
