HELP!
My FTO if driven for long periods starts to surge, It will rev ok but will not drive. If i turn it off and back on it will be ok for 25-30km more?
This does not happen around town only if driven cont for 30min or more.
Any help would be great!. Also how do i order parts and pay for them? THANKS
I have that when i'm completele out of petrol. My suggestion would be to look at your fuel system, and work out if the fuel is being delivered properly.
Im in agreeance with boris sounds like a fuel problem,how much fuel is in the tank when this happens? If its low say less than 1/4 tank it could be some crap in the fuel tank?
make sure you use two spanners to undo the fuel filter, one to hold the fuel line, and one to undo the fuel filter.... make sure you dont twist the fuel line as i did using one wrench...
Yeah my first thought was crap in the fuel line and i have orderd a new filter but yet to rec it as im in Darwin and have to order all my parts from down south takes a while to get here. Just thought that one of you guys may have had this prob before and found it was somthing else.
ruchi wrote:There's also another fuel filter under the back seat.
Heya, I did not know that, I changed the normal fuel filter in the engine bay at 100k, should you change the one under the back seat at the same time ? is it the same type of fuel filter ?
