Im looking into buy a air filter and there are some made by flying performance that are quite cheap is there a reason for this? and do i need to get an airflow meter as well? or should i jus get the uas one with the intake pipe?
thanks
AIR FILTER HELP
- frayli
- smorison
- The Godfather
- payaya
the stock paper element actually provides better filtration than K and N filters. So taking that into consideration not many aftermarket filters so as a good job as the stocky filter element.smorison wrote:flyn are a reseller they don't make anything(off ebay right )...
with airfilters you pay for what you get... cheap can actually be worse than an oem paper filter
is yours a GR or MIVEC???
- Boris
payaya, that's not entirely true.
>> http://www.ftooc.org/contents/pages/project/filter.htm
