Inner wheel guards
Jono
Inner wheel guards
Post by Jono »
hi guys,
just wondering if anyone knows of any particular places and prices for Inner guards?
thanks
Jono
onnzo
Post by onnzo »
Hmmm - I just noticed that mine were ripped to shreds too! Is it a common problem with the FTO?
Im referring to the front guards...
I would just call some wreckers with front cuts.
Mike
HiRAEdd
Post by HiRAEdd »
It's a common problem, especially if you lower the car.
I've been quoted up to $300 a set but I got my replacements from MARK GIBBS PANEL HOUSE, 45 Randall St Slacks Creek 4127, (07) 3808 8737 for $95 each which includes all the plastic lug/screws.
onnzo
Post by onnzo »
That is a lot for a piece of plastic! My car isnt lowered and for $95 a cornorer - I think ill just ignore it :)
TheSentry
Post by TheSentry »
I've got a similar problem on the left front., cept mine is hanging off a bit and hits the tyre when I'm turning. Nothing too drastic but the noise does get annoying sometimes.
[img]http://users.bigpond.net.au/sentry/sig.jpg[/img]
Boris
Post by Boris »
hahahaha... you guys should hear Jono's!!! Now his is loud, even reversing from a normal driveway...
Jono
Post by Jono »
Boris,
you do not have a normal driveway!! hhahaha :P
I was thinking about making my own inner gaurd, using some type of plastic..... wonder if it would be too hard???
Jono
HiRAEdd
Post by HiRAEdd »
It's a rather large, odd-shaped bit of plastic but you could probably make something close to similar if you had an original to use as a template. You may run into a little bit of trouble with the molded areas though.
andux
Post by andux »
Hi All,
I picked up a replacement from my local Mitsubishi dealer (Nunawading Mitsubishi in Melbourne). They had it in stock also. Total cost for one guard including labour was about $200.
The reason I got it replaced was because I noticed stones getting through and hitting the rear of the bottom headlight.
Cheers,
Andux
