Hi peeps, just got my hands on a set of whiteline handling kit!
Consists of adjustable front and rear swaybars plus poly bushes, caster kit and camber kit.
Regarding the adjustable swaybars, does anyone have any idea wats the better setting to install them?
I currently have tein HAs and cusco front strut brace installed.
Intend to get a cusco rear upper and lower brace and also a creative sports lower front brace for AT cars.
GO KART!
Any help appreciated!
Thanks!
Sam
Whiteline kit settings
- wildfaye
- wildfaye
Bump! Anyone?
Does anyone happen to have install pics of the Castor Kit bushes for the FTO?
My mechanic cannot find location with a similar sized bushing at the front lower arms to fit in. They are part number KCA317A right? Its onli two big squarish yellow poly bushes in the kit. No brackets or anything else included.
I've decide to not install the entire handling kit till I have managed to get the correct location of the castor kit.
Any advise appreciated!
Sam
Sam
sam
for the rear sway bar, if you are going to install it, just put it on the softest setting and then go for a drive and see how it feels, if you need the rear to be stiffer put it on the next setting and go for a drive...keep doing that until you find the right setting for you.... i have both the front and the back on the softest setting at the moment...
in regards to the castor bushes, there is only one spot that they can go on! its the rear bush on the front lower control arms... the stock bushes are secured in with brackets and two big bolts on each side../. i think theyre 17mm bolts... one thing to note when installing the castor bushes is that they are more difficult to install than to take out the stock ones because they cause the LCA geometry to change slightly ... when you actually put them in youll know what i mean...
if you have any questions, pm me
cheers
simon
cheers
simon
