Moderators: IMC , Club Staff
andy
Posts: 70 jedwabna poszewka promocja
Post
by andy » Mon Sep 27, 2004 8:02 am
Does anyone know if FTO wheel nuts are common with other cars.
I've lost the key to my locking wheel nuts and I've got to drill them out - but obviously I've got to replace them afterwards!
Cheers
Andy
Boris
Posts: 1448 Joined: Tue Mar 02, 2004 6:00 pm
Post
by Boris » Mon Sep 27, 2004 1:49 pm
Have you tried going around tyre places and asking if they have various lock nut keys?
It worked for a friend of mine, and i'm sure they will have a better solution then drilling it out, which sounds a bit extreme to me
andy
Posts: 70 Joined: Fri Jun 20, 2003 5:00 pm
Post
by andy » Tue Sep 28, 2004 7:12 am
I've found a friend at a local garage who's got a tool for getting them off, but they get destroyed in the process - so I'm back to finding some replacements and needing to know if they are the same as lancers or whatever.
TheSentry
Posts: 328 Joined: Thu May 15, 2003 5:00 pm
Post
by TheSentry » Tue Sep 28, 2004 10:03 am
I'll check when I get home, but I believe you need nuts that are 1.5. And if that doesn't make much sense, they r the same as Magnas.
ruchi
Posts: 1845 Joined: Tue Oct 14, 2003 5:00 pm
Post
by ruchi » Tue Sep 28, 2004 10:12 am
From memory you're right Sentry, they're the same as the Magna
MIVEC is My Friend :D
D-TRAIN
Posts: 589 Joined: Sat Sep 14, 2002 5:00 pm
Post
by D-TRAIN » Tue Sep 28, 2004 1:39 pm
It's a M12 X P1.5
M12 - Diametre of bolt pattern (mm)
P1.5 - Distance between the middle of 2 groove patterns (mm)
I wished I had a diagram to explain.
From FTO to EVO......
andy
Post
by andy » Tue Sep 28, 2004 9:50 pm
Great job guys.
I know what the numbers mean - the P stands for pitch and measures the courseness of the thread, like the old Threads per inch (TPI) used to.
