Has anyone thought of changing the two little light blub on the mirror? i'm sure everyone found it so damn dim, i wanna change it to something brighter, anyone did it before?
ruchi wrote:Slide the two transparent plastic bits back, this will then create a gap where you can pry a small flat head screwdriver in and flick them out.
It is far easier to replace the globes when you have removed the mirror from the windscreen and can hold it in your hands.
so i cant take the whole plastic out? sounds hard to take it out with such a little gap
do you remember the LED blub size name? or is it a one size fit all blub? because i have no idea on this one
As mentioned above, they are a "festoon" - 39mm from memory but 42mm also fits. You can get some REALLY bright 6 and 9 LED 42mm festoon globes, also different colours too.
I've got 6 LED 42mm festoons in mine, they are very bright and very white, it's a bit light a fluoro light
