Fto crank trigger setup
Enginebuilder
Post by Enginebuilder »
Hi guys anyone have the full details on the hall effect trigger on the crankshaft! The ecu has been wired for batch fire and sequential injection as the engine is intended to run! Any help would be much appreciated this is full stand alone emu black!
Re: Fto crank trigger setup
I'm running batch/sequential with a standalone. Here's what mine's set at.
Enginebuilder
Thanks I will take a look today! Do you know what the trigger type is called? Multitooth? Multitooth tooth missing
