Buzzing behind dash
Buzzing behind dash
Hi guys,
When I connect the battery to my car there is a buzzing sound behind the dash.
The door locks get jammed and I can't move them by hand.
I have taken out the fuse for the Door Lock ECU and the problem goes away.
Does anyone know what this could be?
Should I replace the Door Lock ECU or could there be another culprit?
Re: Buzzing behind dash
Dodgy immobilizer somewhere in that circuit? You got keyless entry?
It was removed because it was causing some issues about a year back.
Ac vent selector??
It's definitely central door locking related.
When I remove the fuse for the central door locking there is no issue.
Is there some kind of relay back there perhaps?
